Will A4 wheels fit on a A3?
Old May 24, 2007 | 04:02 AM
ScareGlower's Avatar
Default Will A4 wheels fit on a A3?
Hi all,
Newbie here from the USA - would like to know if A4 rims would fit on an A3.
Thanks!
Old May 24, 2007 | 01:24 PM
phattydre's Avatar
Default RE: Will A4 wheels fit on a A3?
Newer A4s (B6/B7) have similar high-offset wheels that would fit the A3. Which A4 wheels are you looking at? That may help narrow down whether or not they'd fit.
Old May 24, 2007 | 02:10 PM
AWDaholic's Avatar
Senior Administrator
if it's 5x112, and a +35 to +45 offset it will fit anyAudi,mid-'90'sup to current.
Old May 24, 2007 | 03:50 PM
The wheels I'm looking at are the A4 5-spoke wheels. Seller says they are 17x7.5, bolt pattern is 5x112 with a 45 offset.
We have a '07 A3 2.0T.
Will they fit?
Thanks for your help guys!
Old May 24, 2007 | 03:51 PM
phattydre's Avatar
should without difficulty.
Old May 24, 2007 | 05:13 PM
Chef's Avatar
Isn't the factory offset on the A3 like +45/+48?
Old May 24, 2007 | 06:48 PM
Audinam's Avatar
SoCal Crew Member
ORIGINAL: Chef
Yup, offsets lower than 45 won't fit an A3....... trust me, i did my digging for info. that's why i can't have those VMR 714's because the offsets areat 35
Old Sep 14, 2013 | 10:35 AM
Bora Boy's Avatar
I have A3 TDI with sline suspension and have stock A4 wheels with ET42 and 215/55/16 winters and they rub that back (think bumper cover) slightly. I would like to know if going with the OEM tire size for the A3 205/55/16 on the same rim will definitely solve this issue? They look great as they fill the wheel well nicely but read above that I need greater than ET45 to fit.
Old Sep 25, 2013 | 02:15 PM
clt750's Avatar
I just put 2007 S4 wheels on my 2006 A3. 18" from 17". Now I need to lower it a little bit. It looks like a Q5. The biggest pain in the *** was getting those plastic caps off the lug nuts.
[IMG][/IMG]
Old Apr 26, 2023 | 11:53 PM
emank9's Avatar
Default Can you fit
Hey can you fit a Audi s3 2020 wheels 235/35 on a Audi a4 b9 2016 on a 245/40
