****accelerating uphill******
Old Feb 12, 2007 | 09:00 PM
Audi42005's Avatar
Member
Default RE: full throttle up hill ???
o yea and when did i join these forums.......10/27/2004......before all of you.
Old Feb 12, 2007 | 09:01 PM
onepoint8tee's Avatar
ORIGINAL: Audi42005
ok first of all, fu*k all of you. obviously you have no idea what i am talking about and obviously don't know ****. i just gave 3krpm as an example, so your saying that if i am crusin and my rpms are aroud 3k or and need to accelerate up hill i should downshift???? screw that. i obviously know that if my rpms are at 2k then i need to downshift *** hole. My point is that the rpms are high enough to make boost and it accelerates fine, just that it makes a loud engine noise, its not boggingdown at all. i guess that just because i don't have thousands of posts all you idiots think i am new to audi and don't know ****. you guys are rediclious.
http://www.bayareadriving.com/services/stick_shift.htm
Old Feb 12, 2007 | 09:05 PM
Audi42005's Avatar
Member
i guess you think your big **** because your a moderator and have too much time on you hands to sit aroud all day on these forums. i mean i love audi and always will but get a life rather then sitting on here 24/7.
Old Feb 12, 2007 | 09:09 PM
Takes a while to get used to the A4's gear ratio's. Spend a day or two just driving around the block to get used to it, youll catch on.
Old Feb 12, 2007 | 09:11 PM
Audi42005's Avatar
Member
yea because i haven't been driving an A4 for over 4 years.
Old Feb 12, 2007 | 09:13 PM
Ok try this: http://www.ehow.com/how_3234_drive-car-with.html
"You'll know you're in the right gear for your speed if the engine is running smoothly. If it's coughing and sputtering, shift to a lower gear. If the engine noise pitch is too high, shift to a higher gear."
Old Feb 12, 2007 | 09:21 PM
Audi42005's Avatar
Member
ok, the engine is running smoothly, ( not coughing and sputtering ). the noise itself isn't coming from the ENGINE. and the rpms AREN'T too low.
Old Feb 12, 2007 | 09:29 PM
  #18
from your description, the rpms are too low to expect goodpower/smooth op.at full throtle at 2-3k rpms. The turbo doesnt even spool until after 3k rpms. When you give it a bunch of gas bellow 3k rpms in a high gear (especially up hill)you are loading the engine up with a bunch of fuel that cant be burned efficiently which would explain rumbling and slight vibrations... I have experienced this in every manual shift car i have ever owned, and its just a matter of picking the best shift points.
Old Feb 12, 2007 | 09:47 PM
  #19
johnstef's Avatar
going in fith gear start to slow down, u will experience the same exact thing. it means u have to DOWNSHIFT.
Old Feb 12, 2007 | 09:55 PM
  #20
wood_e's Avatar
I will say this, if your clutch was slipping your RPMs would jump.
I was going to try and help if you gave a bit more info, but go screw off... OHHH BIG MAN! Registered in 04 with a whopping 56 posts... yeah, try helping some people and get some respect.
Grow up and them come back here, we won't miss you in the mean time.
