**Two Questions w/ pictures** DV and Coil Packs
Old Oct 5, 2007 | 12:52 AM
qUaTtRoA4's Avatar
Default **Two Questions w/ pictures** DV and Coil Packs
1998.5 A4 1.8T Quattro Manual
Alright, firstly, I am planning on going fmic after getting my chip, which will probably be sometime in November....by the way this is the eBay kit I am looking at, they say it is a complete kit, but no where in the pics can I see a place to attach my DV, so, do I have to cut a hole/fab a flange...or am I missing something?
here's a pic of what I am talking about
oh, and on the same note, would I be able to move the DV any closer to the turbo inlet pipe, or would the turbo's turbulance have some sort of negative effect? (mainly thinking in terms of making the the DV release a little more audible)
My second question is totally irrelevant to the first, and is basically presented to you in this pic
I have two of each of the 4 pin packs...they were given to me by a guy who had no idea what they came off of, so i am mainly wondering what application they are for...is there an application guide somewhere for coilpacks?
well, I believe that is it for now, any and all help is appreciated
Old Oct 5, 2007 | 01:03 AM
cincyTT's Avatar
I'm make believe
Default RE: **Two Questions w/ pictures** DV and Coil Packs
i would believe you reuse the turbo hose with the dv recirc on it when installing the new fmic. If you want your blow off to be more audiable, get a intake, cut holes in your airbox and/or get a piston based dv.
As for the packs, look on ecstuning for more info.
Old Oct 5, 2007 | 02:10 AM
qUaTtRoA4's Avatar
Thank you cincy...yeah, I wasn't planning on using the stock hose, I think I'll just weld a little flange on the kit...
as for making the DV more audible, I just bought a piston based DV, and I already do have a custom K&N intake/heatshield....
so, is there a reason why I shouldn't get my DV any closer to the TIP?
I've been looking everywhere trying to find the application for the two different BREMI packs, I already looked on ecstuning.com, but I will look again...
if any of the techs on here have an application guide for the bremi pacs, it would be much appreciated if you could tell me what cars the coils correspond to...
thanks again!
Old Oct 5, 2007 | 09:09 AM
Bondga's Avatar
if you are wanting to move your dv you should move it closer to your throttle body. it will do the most good over there
Old Oct 5, 2007 | 09:15 AM
kraylon's Avatar
what ebay kit are you looking at??
Old Oct 5, 2007 | 01:46 PM
cincyTT's Avatar
I'm make believe
if you have a intake already, then you need to place the valve over the charge pipe and put the pressure on the bottom. This will increase the the sound by a few more dB.
Old Oct 5, 2007 | 05:45 PM
Leifer's Avatar
ORIGINAL: Bondga
I never understood that fully. Why does it make a difference as to where you move the DV?
Old Oct 5, 2007 | 07:05 PM
cincyTT's Avatar
I'm make believe
The further the dv/bov is from the turbo, the faster the turbo will respool since the turbo will spin faster between shifts since it is moving more air between shifts.
Old Oct 6, 2007 | 01:31 AM
qUaTtRoA4's Avatar
ORIGINAL: cincyTT
that's good to know!...thank you!
I figured out that the coils came off of a 2003 Passat GLS 1.8T Tip 2 of the packs are the newer styles(j(the good ones) and two of the packs were from the factory (H9which are the sh!tty ones))...in case anyone needs to know....they were from an AWT motor and I am pretty sure they'll also work on the 1.8T A6....
drft1
Jul 5, 2010 12:19 PM
kraylon
Jul 29, 2009 12:19 AM
gibson 01
Aug 15, 2008 01:20 PM
ZGSON
Jan 27, 2008 11:17 AM
quattrosedan
Jul 20, 2005 12:59 AM
