*updated* Engine Dies After 1500 RPM
RE: Engine Dies After 1500 RPM
Hope this helps. It was too involved for me to fully go through, so I just sent it. Formatting was lost. The first thing I'd check are connections and then try a throttle body alighnment and see if that does anything. Easy and cheap to do.
ok i did what david posted, checked the voltages on the connector, they were fine, did more searching on audiworld and the zine, and i thought i narrowed it down to a bad throttle body. ordered one from ecs, got it today, replaced it and it is still the same issue, dies at 1500 rpm, almost like at 1500, the car is shut off and then turns back on again, still getting code p1545 tp sensor failure. I am lost and stressed.
#20
RE: *updated* Engine Dies After 1500 RPM
ORIGINAL: 99silverA6
i had to re-adapt my Electronic Fuel Control Valve using VAG tool.
01 - Engine, then what value do I need to do a measuring blocks/basic settings on?
Cheers.
