01 boost question
Old Sep 8, 2007 | 07:42 PM
SilverA4q's Avatar
Default 01 boost question
I just bought my 01 a couple months ago and justput in my boost gauge. Its the only mode i have so far. i searched the forums and found that most stock A4 are running 7 psi. My car is boosting at 10-11 psi. How could that be? Need some help figuring this out.
Old Sep 8, 2007 | 07:44 PM
cincyTT's Avatar
I'm make believe
Default RE: 01 boost question
either you have in a differnt n75 or your gauge is off. Im going with the first one
Old Sep 8, 2007 | 08:03 PM
qUaTtRoA4's Avatar
that sounds normal to me....the 10-11 is a normal spike on my a4 in 90-100 deg weather...during the cold months I spike at 13-14...but I usually hold between 7 and 9psi...
sounds like you don't quite have a handle on what you are looking at, the turbo psi will spool up super high and then it will gradually decrease in the higher rpms until it completely stops and holds at a single psi level (7 or 8 psi stock)...
the 10 to 11 you see is most likely your spike, if not there are one of two things you must take into conseideration
1-you bought a piece of **** boost guage that doesn't work
2-you are chipped, you could have a really lousy tune or an intense boost leak
good luck!
Old Sep 8, 2007 | 08:15 PM
SilverA4q's Avatar
ok thanks for the info the spike is what must have been seeing at 10-11. I have a VDO boost/vac gauge.What should my vac be at?
Old Sep 8, 2007 | 08:23 PM
cincyTT's Avatar
I'm make believe
~20in hg when the car is at operating temps
Old Sep 8, 2007 | 08:37 PM
SilverA4q's Avatar
ok good thats what im at right now.How will i know if i have a boost or vac leak?
Old Sep 8, 2007 | 08:41 PM
qUaTtRoA4's Avatar
if your boost is low its a boost leak, if your vac is low its a vac...and if there both low you either have both or a bad guage...
good to hear your guage is working well, it will help you big time in the future, espacially after you get chipped
Old Sep 8, 2007 | 08:49 PM
SilverA4q's Avatar
yeah i like it im hoping to get it chipped here next month. Im about a half hour from and APR dealer so im gunna go with the 93 chip.
Old Sep 8, 2007 | 08:53 PM
cincyTT's Avatar
I'm make believe
Here is something simple i want you to do. Go to your n75 and see if its still on-time-use clamped into the intake. If the answer is no, then like i said before, your most likely not using the stock n75.
Old Sep 8, 2007 | 09:02 PM
SilverA4q's Avatar
what do you mean on-time-use?
