03 audi a4 1.8t turbo valve noise
hello I resently had some work done to my audi and had to replace my turbo with 65,000 miles. when i did i sounded fine until i got a muffler for it, then I noticed everytime I accelerated hard or suddenly then let off quick the valve for the turbo (im gussing) sounds like a bov would sound like a wistle. So i put my stock muffers back on but it still makes the same noise. I just am not sure if its something I should worry about or not, its normal when I start going it spools up and everything and seems like its getting the right amount of boost just when I let off, sometimes event easy it will make a "chirp" sound or high pitch wistle for around .5-1 sec. So any help on this problem or explanation would be great thanks.
ORIGINAL: bnp25
well i have an 01 a4 1.8t 5v (same engine) and it never makes that noise
No, thats your PCV check valve. The dv is below your passenger side headlight. And no, swaping to a 007 wont do anything but improve performance if the stock dv is weak/torn
redfire2002
Oct 23, 2008 02:04 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
