03 audi a4 1.8t turbo valve noise
Old Nov 22, 2007 | 04:37 AM
bnp25's Avatar
Default 03 audi a4 1.8t turbo valve noise
hello I resently had some work done to my audi and had to replace my turbo with 65,000 miles. when i did i sounded fine until i got a muffler for it, then I noticed everytime I accelerated hard or suddenly then let off quick the valve for the turbo (im gussing) sounds like a bov would sound like a wistle. So i put my stock muffers back on but it still makes the same noise. I just am not sure if its something I should worry about or not, its normal when I start going it spools up and everything and seems like its getting the right amount of boost just when I let off, sometimes event easy it will make a "chirp" sound or high pitch wistle for around .5-1 sec. So any help on this problem or explanation would be great thanks.
Old Nov 22, 2007 | 04:43 AM
kolan67's Avatar
Default RE: 03 audi a4 1.8t turbo valve noise
It's gona explodeeeeeeeeeeeeeeeeeeee
its normal
Old Nov 22, 2007 | 04:44 AM
bnp25's Avatar
well i have an 01 a4 1.8t 5v (same engine) and it never makes that noise
Old Nov 25, 2007 | 05:14 PM
bnp25's Avatar
so how would it be normal?
Old Nov 25, 2007 | 05:23 PM
Papachristou's Avatar
sounds like DV is failing.... thats what my R1 did before it went out
Old Nov 25, 2007 | 05:28 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: bnp25
if its when you lift off the gas, its the dv (diverter valve), it is normal. If you take the airbox cover and filter out you can hear it better. If it sounds like a splash or psshhh, its fine, if it sounds like a rapped goose, you have a blown/torn dv and it needs replacing
Old Nov 27, 2007 | 02:05 AM
bnp25's Avatar
if i replaced it with a forge 007 dv would the engine light come on and will it do anything to the turbo
Old Nov 28, 2007 | 12:35 AM
bnp25's Avatar
and is it the black round thing at the top left of the engine?
Old Nov 28, 2007 | 12:38 AM
cincyTT's Avatar
I'm make believe
No, thats your PCV check valve. The dv is below your passenger side headlight. And no, swaping to a 007 wont do anything but improve performance if the stock dv is weak/torn
07titanium
B7 Models
Oct 25, 2011 08:11 PM
Executor
Apr 2, 2010 05:16 PM
redfire2002
Oct 23, 2008 02:04 PM
97_blue_a4
Sep 30, 2008 12:08 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
