09 Audi A4 2.0T Intake Leak, Misfire
Old Sep 5, 2018 | 10:54 PM
tenteromano's Avatar
Exclamation 09 Audi A4 2.0T Intake Leak, Misfire
CAR: 2009 AUDI A4 2.0T
CODES: P2015: INTAKE MANIFOLD RUNNER POSITION SENSOR/SWITCH CIRCUIT RANGE/PERFORMANCE BANK 1A . P0300 RANDOM/MULTIPLE CYLINDER MISFIRE DETECTED . P0304 CYLINDER 4 MISFIRE DETECTED . P0302 CYLINDER 2 MISFIRE . P2279 INTAKE AIR SYSTEM LEAK . P0301 CYLINDER 1 MISFIRE .
ISSUE: Driving home from work today my EPC and check engine light came on, the engine was also shaking. Right away I knew it was a misfire and got home to scan the ECM. I found the codes above using my scanner. The engine is misfiring during idle and under load. RPM's are bouncing around. Not sure what it is exactly, I know it could be the ignition coils, spark plugs, PCV valve.
Can anyone help me narrow down this issue? I don't want to buy all the parts and it just be the coils etc.
Old Sep 8, 2018 | 04:28 PM
StackA4's Avatar
Default Need help on this as well
Audi dealership says I need 12k worth of work
b.hasz
Feb 24, 2010 02:19 AM
trevor51590
Jul 14, 2009 11:55 PM
themahr
Mar 31, 2009 03:50 PM
Jahbless298
Jul 10, 2008 01:48 AM
trevor51590
Apr 20, 2008 01:52 AM
