1.8t big turbo setup low boost
Old Sep 27, 2006 | 04:04 PM
InsaneHatter's Avatar
Default RE: 1.8t big turbo setup low boost
contact Chris Tapp .. he will set you up w/ a great software solution for your turbo.. it will require 630/660 CC injectors though...
if you are DBC disconnecting the MAF will do nothing... if you are DBW then the MAP sensor should take over .. but I think it can only read 1.5 bar or something similar.
Old Sep 27, 2006 | 05:24 PM
aRIf's Avatar
I think name of the company is Absulut or something like that. They have program for t3/t4
Old Sep 27, 2006 | 05:36 PM
Upsolute???? ^^^ I think they are DBW tuning as well... so yea.. WHAT MY ARE YOU
Old Sep 27, 2006 | 05:46 PM
onepoint8tee's Avatar
Ehhhhhhh.... A4intec, i would not be driving your car in its current condition... You must be running really lean... Yikes... [&:]
You were probably better off running with a boost leak without having the correct injectors/software. Fixing that leak is only gunna make you run even more lean without the right fuel setup/software.
If you continue to drive it like this, i can only hope that limp mode saves you from the potential consequences of a half assed setup.
Old Sep 27, 2006 | 09:09 PM
quattrosedan's Avatar
Any idea on how much there tuning would cost for the t3t4?
Old Sep 27, 2006 | 10:43 PM
Chris tap is like $800 for a 2 file program .. which is pump/race... not bad considering he is a great tuner and uni's cost 925$ or something
Old Sep 27, 2006 | 10:57 PM
aRIf's Avatar
as far as I know, the only problem Upsolute was idle problem but not biggy.
Old Sep 27, 2006 | 11:01 PM
  #18
BadLuckAudi's Avatar
lol a small idle prob is much better than rods out the side of the block, IMO
ORIGINAL: aRIf
Old Sep 28, 2006 | 02:21 AM
  #19
aRIf's Avatar
Turbo............................................. $800
660cc injectors................................$300
Bov............................................... .$200
Mbc............................................... ..$100
Run a big a$$ turbo with stock ecu.... priceless
Old Oct 15, 2006 | 10:01 PM
  #20
a4intec's Avatar
How do I contact Chis Tapp
