1.8t big turbo setup low boost
contact Chris Tapp .. he will set you up w/ a great software solution for your turbo.. it will require 630/660 CC injectors though...
if you are DBC disconnecting the MAF will do nothing... if you are DBW then the MAP sensor should take over .. but I think it can only read 1.5 bar or something similar.
Ehhhhhhh.... A4intec, i would not be driving your car in its current condition... You must be running really lean... Yikes... [&:]
You were probably better off running with a boost leak without having the correct injectors/software. Fixing that leak is only gunna make you run even more lean without the right fuel setup/software.
If you continue to drive it like this, i can only hope that limp mode saves you from the potential consequences of a half assed setup.
lol a small idle prob is much better than rods out the side of the block, IMO
ORIGINAL: aRIf
as far as I know, the only problem Upsolute was idle problem but not biggy.
Turbo............................................. $800
660cc injectors................................$300
Bov............................................... .$200
Mbc............................................... ..$100
Run a big a$$ turbo with stock ecu.... priceless
