Depends on the year. The VW versions of the 1.8t are transverse and the oil pan and oil screen pick up are different.
yup, and the way the water pump bolts on is different for some years, plus the motor mount brackets are different on some years.
RE: IS the 1.8T GTI engine the same as the 1.8T A4?
Quote:
ORIGINAL: Pson
No none of the 1.8T form Jetta will fit an A4...you need a long mounted, plus the tranny systems are diff too
Wasn't aware he asked that. Guess I read wrong.ORIGINAL: Pson
Tech Guru
wouldn't a 1.8t in both be the same or similar if they are both fwd cars?
- Cold Engine (Like off for 12 hours) Radiator Fan Comes On Full Blast with engine Off.
- 1983 Audi Ur Quattro, 20v turbo engine, 62k miles, $15k engine swap!
- A3 leaking engine coolant + AC causing loud fan noise from engine
- Engine power sucks, replaced MAF, didn't help - engine codes inside...
