Sponsored by:
Sponsored by:
10.69 @135 mph!!!! (video)
  #21
Old 09-11-2007, 06:05 PM
cincyTT's Avatar
I'm make believe
Default RE: 10.69 @135 mph!!!!
ORIGINAL: sean1.8t
remember he has had to rebuild the engine twice
what for?
  #22
Old 09-11-2007, 06:14 PM
sean1.8t's Avatar
ORIGINAL: cincyTT
AEG crank
Scat rods
Wiseco 83mm 9.25:1 pistons (i like compression, good for spool)
Stock ATC block same as AWD
83.5 is beyond what you should use for a street car, guessing same sources. Plus the 24cc's isnt worth the thinner cylinder walls. If you use a TDI block and crank you can go 2.1L but you cant rev as high as with the 92.8 crank. Basically, its the same as stock.
or if you use a 2.0l ABA block with the Otteginer 99mm crank you can get it up to 2.2l with as much of a rev limit your head will allow
  #23
Old 09-11-2007, 06:15 PM
sean1.8t's Avatar
ORIGINAL: cincyTT
ORIGINAL: sean1.8t
what for?
due to a knife edged crank for one. and also the machine shop he originally used did not balance the engine to spec. it basically vibrated itself apart
  #24
Old 09-11-2007, 06:35 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: sean1.8t
Let me guess....eurospec?
  #25
Old 09-11-2007, 06:46 PM
sean1.8t's Avatar
im actually not sure which crank he had prior. my guess would be eurospec. but he could have had a different ABA crank knife edged
  #26
Old 09-11-2007, 07:02 PM
cincyTT's Avatar
I'm make believe
I have seen a few people complain about their knife edge crank causing serious damage. Ill stick with a nicer factory part myself
  #27
Old 09-12-2007, 05:39 AM
Flarika's Avatar
Wow!! Pretty awesome! (I'm still cheesin' over the R8 vs. 997 clip though)
PostRelease
07-28-2010 01:15 PM
PostRelease
07-28-2010 01:15 PM
PostRelease
07-28-2010 01:15 PM
A3Night
07-03-2006 01:33 AM
Quick Reply: 10.69 @135 mph!!!! (video)
