12 volt power in the trunk?
Old Aug 5, 2004 | 01:20 PM
Marc911951's Avatar
Default 12 volt power in the trunk?
Hi all,
Installing an an XM radio tuner and using the adaptor for the changer in the trunk.
I will need a 12v ignition switched and probably a 12v constant.
Whats best to tap into?
I have owned this car less than 24 hours so not too familiar yet.
Thanks!
Old Aug 5, 2004 | 01:23 PM
shon's Avatar
Default RE: 12 volt power in the trunk?
what car?
and if your using the cd changers wiring shouldnt it have the power wires you need?
Old Aug 5, 2004 | 01:33 PM
Marc911951's Avatar
The car in my sig, 2000 S4.
I am told the adaptor does not support power.
Thanks
Old Aug 5, 2004 | 02:20 PM
shon's Avatar
would you have a problem running a 12v power from the fuse box?
Old Aug 5, 2004 | 02:22 PM
Marc911951's Avatar
I was trying to avoid the wire run to the fuse box but that is what I planned to do if there was no better way.
Old Aug 5, 2004 | 06:55 PM
Jestnomen's Avatar
6th Gear
It's really easy to run a 12v power supply from the battery. I ran mine through the ECU box under the molding and into the trunk. Took all but 30 minutes to do it.
Old Aug 5, 2004 | 11:20 PM
audiboy1618's Avatar
Thats what i did when i was installing my boost gauge only i went to the dash.
Old Aug 6, 2004 | 12:43 AM
shon's Avatar
if i was putting a boost guage in a vent, (the drivers side) does the wire harness that goes to the back of the vent have a power wire? because it does light up the vent wheel...?
would like to get around running a new wire for a boost guage...
Old Aug 6, 2004 | 02:42 AM
brrman's Avatar
Under the knee bolster is a 75x power post which is "switched power" - best place to get it. Only on when ignition is turned on (or in accessory position).
I ran a wire from that post to my boost gauge in my vent install. I ran all kinds of crap off that 75x post.
Old Aug 6, 2004 | 03:36 AM
shon's Avatar
im sorry, knee bolster?
