19" Take away power??
The diameter of the wheel and tire usually remains pretty close, that is not the factor.
Its the weight of the wheel that matters. More weight = a higher rotational mass = which makes the car need more hp to reach the same speed.
Its the same reason a lot of car tuners get a lightweight crank pully, the much lower weight of the pulleyand sometimes slightly smaller size, gives it a lot lower rotational mass,and frees up more horsepower from the engine because the power can go to to the tranny instead of to turning the crank pulley.
So, if you buy 19s, and the overall diameter of the wheel and tire are the same, as long as the wieght of the wheel is the same, you shouldn't noticea difference. If they are heavier, you'll lose a few hp, if they're lighter, you'll gain a few hp.
So, when ever you buy new wheels, (no matter what size)you should take the weight of the wheels into consideration as one of theimportant factors.
OK I have changed my mind then. I want to have bigger rims but I dont want to lose much power doing it so I think I'm gonna go 18's. Tell me what you guys think about these rims and tires and if they will work for me. Thanks.
18" ADR Spartans http://cgi.ebay.com/ebaymotors/18-Bl...spagenameZWDVW
235/40/ZR18 Toyo Proxes 4 http://www.1010tires.com/tire.asp?ti...&pc=197090
ORIGINAL: banderson121
Atta boy. I did the same thing
Its been a while since i researched them but i think 15-20lbs. I asked months ago what the stock 17's weighed but i dont think i got an answer. I would prefer to stay as close to that if not lighter. HRR (think thats the brand) has some light rims but are expensive, but would be a good reference.
ORIGINAL: akielb
This is a stupid analogy. for your comment to make any sense the person would have to have no tires on the wheels - for tires the diameter, circumference should be the same, doesn't matter if you have 15's or 19's
If you change the analogy to "imagine a mouse trying to spin a 10lb rim versus a 20lb rim how much more power would be needed to spin the larger" that would be true
If I race you with a 16" rim and it weighs 15lbs and I have 19's that are really expensive light weigh models then we would be more of a comparison.
In conclusion size doesn't matter
ORIGINAL: nvus1too
Imagine a mouse on one of those stupid wheels. The bigger the wheel, the faster the mouse has to run to make it spin.
