from 19 to 25 psi with a 3 in maf?
Old Aug 7, 2005 | 08:57 PM
black991.8tq's Avatar
Default from 19 to 25 psi with a 3 in maf?
so on friday night i put a 3 in maf on my car and the boost went from 19 psi to 25 psi? the car felt great but i think i blew odf a vac line or an intercooler pipe cause on the way home i was only getting 5 psi. i havent been able to check it cause later friday night i had to go to the hosipital and have my appendix removed. any ideas on why i would get that much more boost or was the stock one that restrictive.
Old Aug 7, 2005 | 09:44 PM
Jeff's Avatar
Zombie Defense Force
Default RE: from 19 to 25 psi with a 3 in maf?
you didnt blow the ic pipe off cus then you would have no boost maybe split it. also u may of gone into limp mode. another safety thing put in by audi that kicks the boost down if it notices to much boost
Old Aug 8, 2005 | 12:37 AM
i really hope it is a vac line.
Old Aug 8, 2005 | 01:47 AM
black b5's Avatar
sounds like you just hit limp mode.
i always get throttle cut when i hit 25 psi, i need a MBC to cut off the spikes
i hope all is well with the appendix
Old Aug 8, 2005 | 01:52 AM
lidonnit's Avatar
If the car has been off for a few hours, then it shouldn't be in limp mode now. Next time you drive it you should be able to get 25 psi again. If not then you have a problem. I would say it is Limp Mode though.
Old Aug 8, 2005 | 02:07 AM
no i dont think it is limp mode it sat for 2 days, i started it today and it was only hittin 5 psi
Old Aug 8, 2005 | 07:22 PM
mmart6545's Avatar
ORIGINAL: black991.8tq
Question - why did you go to a 3 inch maf?
You cant change the maf without changing your tuning. i'm 99.9999% sure your tuning doesnt support it, so why bother? You are doing more harm then good (as evidented by the fact your car is now limping)
