1998 a4 headlights
Old Jun 15, 2007 | 12:11 PM
rob51300's Avatar
Default 1998 a4 headlights
My headlights wont work, they work when i pull in the highbeams, but other than that, i got nothing. Ive heard this is a comon problem and more than likely, its either a blown relay switch or a dirty one. However i am having trouble locating the relay. Any info on where it is would be appreciated. Thanks
Old Jun 15, 2007 | 03:30 PM
acetrebo's Avatar
Default RE: 1998 a4 headlights
Its likely the headlight switch in the steering column.
Here is the write up for the exact problem you are experiencing.
http://www.audiworld.com/tech/elec114.shtml
Old Jun 17, 2007 | 05:36 PM
dombombBMX's Avatar
hey man i just had this problem... its the ingnition switch.. (when i went to the dealership to get the new part they said there is no such thing as a relay switch only x relay.) whatva.. but for sure is the ignition switch.. i just had this happen.. you have to take your steering wheel and all that chunk.. its suprisingly easy just like 10 bolts to loosen....
Old Jun 20, 2007 | 04:51 PM
rob51300's Avatar
Thanks for the info guys.....def exactly what i needed.
Thanks
1998a4peterson
Jun 9, 2011 10:15 AM
switchusmc
Jan 2, 2011 08:27 PM
dan5342
Aug 17, 2007 12:27 AM
hyland
May 24, 2007 04:52 PM
marniepira
Jan 25, 2007 02:46 PM
