1999 a 4 dtc codes
Old Dec 27, 2007 | 04:58 PM
re07fueler's Avatar
Default 1999 a 4 dtc codes
I have a 1999.5 a 4 5 spd. man. quattro with a 1.8 turbo. I retrived the dtc codes and they are 17953, throttle pos. control malfuntion and 17967, idle speed cont. throttle pos. adaption malfuntion. I don't know what these codes are telling me is wrong, I was told to replace the throttle body that didn't correct the problem. The car starts but when the gas pedal is depressed the engine can't decide where the proper engine rpm should be it oscillates about 1000 rpms up and down. Any help would greatly appreciated its snowing out and I want my audi back thanks
Old Dec 27, 2007 | 06:03 PM
CRAZYHAWK's Avatar
Default RE: 1999 a 4 dtc codes
Do a throttle alignment. Disconnect the battery, make sure
you have the radio code. Wait a few minutes and reconnect
the battery. Turn the key part way, do not crank the engine.
The throttle will align itself in 2 minutes.
dberberick
Sep 23, 2013 09:04 AM
Mark(A6-A4)Ct
Mar 19, 2013 11:21 PM
erasmmuss
Feb 28, 2011 12:40 PM
smogs1
Apr 19, 2009 07:20 PM
re07fueler
Dec 27, 2007 04:16 PM
