1999 A4 1.8t weird intake sound above 3k - stalls - sucking air sound
Old Jan 31, 2008 | 11:29 PM
jasmix's Avatar
Default 1999 A4 1.8t weird intake sound above 3k - stalls - sucking air sound
Ok this just started hapening yesterday.... it idles drives fine right above 3000rpm it makes like a sucking noise and you can hear from the intake..
if you push it like 4-5k RPM it tries to accelerate but i dont wanna break anything
i took out the MAF cleaned it no change its like a rough sucking sound?
whats going on...
Old Jan 31, 2008 | 11:50 PM
chaos92287's Avatar
Default RE: 1999 A4 1.8t weird intake sound above 3k - stalls - sucking air sound
might be an exhaust leak or boost leak
Old Jan 31, 2008 | 11:58 PM
jasmix's Avatar
but nothing serious i suppose? like my turbo going bad or the DV
Old Feb 1, 2008 | 12:01 AM
chaos92287's Avatar
if your turbo was going bad you would know it. that sound is unmistakable. and i doubt its the dv
Old Feb 1, 2008 | 01:11 AM
Rhinop21's Avatar
Its kind of hard to tell from your description but I would say boost leak. Go get a boost gauge!
Old Feb 1, 2008 | 01:28 AM
jasmix's Avatar
hmm...whats the steady boost that I should see on the gauge...without accelerating
Old Feb 1, 2008 | 01:36 AM
cincyTT's Avatar
I'm make believe
You have a massive boost or vac leak. Thats why the car is stalling. You probably have it to where you can make some boost, but when you change gears, its stalls. Its basically like a bov that is open at idle, you leak a massive amount of metered air.
Old Feb 1, 2008 | 02:34 AM
chaos92287's Avatar
ORIGINAL: jasmix
you shouldn't be boosting at all if your not accelerating
Old Feb 1, 2008 | 06:10 PM
jasmix's Avatar
its raining crazy but ill check tommorow...its doing above 3k rpm so cant drive much doesnt matter what gear....
chusaiyan
Jan 16, 2008 08:58 PM
Babz
Apr 9, 2007 05:35 PM
J_Charisma
Oct 30, 2006 05:13 AM
A4Petro
Jul 9, 2005 10:16 AM
Peteman187
May 11, 2005 08:47 PM
