19x8.5 w/ 32 offset on b5
Subscribe
Jul 20, 2006 | 06:09 PM
235/35/19
will I rub? Mess up my control arms?
Need answer asap, tried to search, but couldnt really find what I was looking for.
Reply
Jul 24, 2006 | 03:28 PM
RE: 19x8.5 w/ 32 offset on b5
Should be fine at the back. Good offset for the 8.5inch
Though the front might rub the inner guard on full lock
Reply
Jul 24, 2006 | 08:12 PM
I think 19s don't look good on a b5, just looks too big plus the fitment issues. 18s are better IMO
Reply
Jul 24, 2006 | 08:47 PM
They will not rub.....18's look like **** on B5's and alot of people will tell you to not get 19's. Go 19 you'll be glad you did imo!
Reply
Jul 24, 2006 | 10:05 PM
If you lower it, it will rub. I had 18x8.5 with a 35 mm offset on my b5, and the wheels were flush with the fenders. I had to roll the fenders. So a 32 offset will be even worse.
Reply
Jul 25, 2006 | 12:59 AM
Quote:
ORIGINAL: flyinb501
Hey..your wheel/tire set is exactly how I want my own to fit on my B6..so, give up the specs!?!??! width, offset, etc
Reply
Jul 25, 2006 | 05:18 AM
Front: 19x8.5 w/ 35 mm offset
Rear: 19x9.5 w/ 35 mm offset
Reply
Jul 26, 2006 | 07:31 AM
I just fit my 19x8.5 with 40 offset.. look huge on the car! (has lowered koni shocks and springs)
It looks like it need a lower bodykit big time now!
Anyways, after fitting my 19's, i think flyinb is right.. with 32mm offset it will stick out and touch the fender with lowered suspension. My 40mm offset sit just inside the fender and dont rub. But with my 40mm offset, u get occasional rub on the shock body at the rear, and front toe joint.
Beermod, have u lowered ur B5 yet? On bumps at high speed, the front tires seem to hit the upper toe join above the wheels and make that squeel noise. This happen to you? Any rub at the back? What offset and width wheel?
Optimum specs for 19's though would be 19x8 with ET of 35
Reply
Jul 26, 2006 | 04:09 PM
i agree 19's are the only way to go for a b5, and if it rubs have your fenders rolled......and you can get upgraded control arms fro Blauparts.com
Reply
Subscribe
