2.8/3.0 30 valve FAQ guide
Old Dec 7, 2005 | 06:17 PM
Grouse's Avatar
Default 2.8/3.0 30 valve FAQ guide
I have been putting this together. Most of the links show parts for the 2.8/30v at the same pages.
It was mentioned that this was helpful. I added some links.
Stuff for 3.0/2.8 30 valve
Exhaust:
Neuspeed
http://www.greedspeed.com/applicatio...ST_V6_QUATTRO_
Decorsa:
http://www.ecodetuning.com/shop/cart...ail&p=446&c=18
Thermal:
http://www.ecodetuning.com/shop/cart...ail&p=359&c=18
Milltek (all the way down 2nd from the bottom)
http://www.stratmosphere.com/milltek_a4_catback.htm
Supersprint:
http://www.supersprintna.com/categor..._model%5D/171/
Chip:
Neuspeed
http://www.greedspeed.com/applicatio...0v.aspx?cat=46
Giac:
Does not show it but my local dealer Evolution Assures me that they have a chip flash for the 3.0.
www.evolutionsports.com
Wetterauer
http://www.autobraun.com/abd/chiptun...l.asp?ct_id=12
Intake:
Stratmosphere:
http://www.stratmosphere.com/hyperflow.htm
Intake shoot out article
http://eurotuner.com/techarticles/0411et_intake/
SuperCharger:
Pes G3:
http://www.pes-tuning.com/
MTM Twin Screw Supercharger
http://www.mtm-online.de/en/index.ph...m=MCA4220315FX
Twin Turbo One Off 2.8's and 3.0's
2.8 passat twin turbo thread
http://www.passatworld.com/forums/sh...2&page=1&pp=30
TVA motorsport one off 3.0 twin turbo at .7 bar.
http://www.audi-sport.dk/audi_a4_3.0_turbo.htm
These are the only two twin turbo's i know about and Niether has responded to my pm's emails.
Intake, exhaust, and chip will net you 12-18 hp. Not a whole lot, your running a n/a motor.
You can do a 50 wet shot of nitrous. There are a few around who do, they tend to stay quite as some of the members here are asshats about nitrous only being for ricers.
The pes system puts down 320 chp, and 268 ctorque. that translates to about 256whp and 213 wtorque. Winslow at PES thinks with intake and The new thermal exhaust that thermal made specifically for the g3 they can hit 350 chp witch would put you at 270-275 whp.
The g3 is the eaton roots e-62 supercharger, it hits 10 psi at full boost, This is the safe long term functioning limit PES has found on the 2.8/3.0 30v engines. Winslow says if you want to go higher with the G3 you'll need to beef up the bottom end. As for the top end their testing shows the g2/g3 actually benefits from all of the turbulence increasing the mixture of the compressed air and fuel. This gives better fuel air mix for ignitions. The g3 is their third supercharger for the 2.8/3.0 30v, it started with the g1, then the g2, and the final version of the g3 for the 3.0 30v.
3.0 king has a g3 with intake and supersprint exhaust and shows 335 chp. That puts him at s4 power with 3.0 gas mileage and about 5k less new. Out of the g2's and g1's there are some that are in the 60k to 90k in mileage, is this the standard yeah I believe so. the e-62 is a near bullet proof s/c not nearly as high strung as a big turbo kit for the 1.8t's. If
If your looking for near instant boost, with s4 power, but the gas savings of a 3.0. This will fit the bill.
When i asked winslow about speed comparisons he said the g3 will beat a chipped and exhaust 4.2 s4, and a chipped 996 will need a long long road to actually take the g3, and it finally does at 6th gear and about 6k in rpm.
Obligatory info to support what i said
These two dyno's are from a 3.0a4 quattro. so the numbers are quattro WHP numbers. multiply them by 1.21/1.22 some where in there to get your numbers at the crank.
Several guys with the g3 make more than the advertised 320. 3.0king makes 335 with stratospher cai and supersprint exhaust.
Last I talked with Winslow he was thinking that the new thermal exhaust specifically made for the g3 could possibly bring it up to about 350 chp. which would translate into 273 whp on a quattro a4.
I asked about
Port and polish of the top end, headers, manifold extrude and hone, 50 hp shot of nitros... your best of hearing his answers directly from him.
For those two lazy to call.
*Port and polish. Will run you about 12-1500 for… almost no gain times that people have done it on the g2 they range with in 5-8 hp on their dyno’s that is well with in the margin of error for environmental conditions.
* Headers run around 1100 for the 2.8/3.0 if you can find them. I did once but lost the link. Pes tested the headers on the G2 and saw a gain of 8-10 hp. for 1100 plus one hellatious install it was a bit of a stretch.
*Extruding and honing of the Manifold. PES’s is a custom manifold. What little rough ness it has is likely to give the air a bit of turbulence. This tumble seems in Winslow’s opinion to be more beneficial to the operation than a clean charge. It forces the air and fuel to mix at a much more efficient level.
*Nitrous in addition to the G3 has not really been tried. Give it a shot :P and let Winslow know.
anywho, I hope that helps.
this is a dyno on the g2 done on a fwd passat 2.8 this will give you a comparison of the hp loss due to Quattro 21/22% versus around 9% drive train loss for FWD.
***** 3.0 kings eurotuner article
Old Dec 7, 2005 | 06:39 PM
Raddue's Avatar
Default RE: 2.8/3.0 30 valve FAQ guide
Great information for us 2.8L 30v owners. Thanks, Grouse!
Old Dec 7, 2005 | 07:31 PM
Jeff's Avatar
Zombie Defense Force
great post[sm=happybounce.gif]
Old Dec 8, 2005 | 05:20 PM
Railslider's Avatar
Grouse = Pimp. You ready for another GTG?
Old Dec 8, 2005 | 05:59 PM
TheJazz7's Avatar
Awesome, very helpful in my search for a good chip and exhuast.
2.8 representing beyotch!
Old Dec 8, 2005 | 07:05 PM
Grouse's Avatar
I want to clean it up and put more 2.8 stuff and dyno's and more g1/g2 dyno's along with some 12v comments.
I'll hand it off to redgoat when i am done.
Old Dec 9, 2005 | 03:22 PM
Grouse's Avatar
I've got an updated version, for you redgoat. I'll work on the 2.8 portion tonite.
elduderino200
Jul 8, 2015 03:35 PM
gabeguimaraes
May 22, 2009 04:46 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
