2.8 cam shaft adjuster seal leak?
Anyone else encountered a large oil leak on a '98-99 2.8 30V coming from the cam adjuster seal? Dealer wants $1200 to fix it, which I don't have. Car's driveable, but I'm wondering if it's something that is easy to replace and just time consuming or if it's something I just shouldn't touch. Anyone else dealt with tt before?
Thanks.
Thanks.
how many miles are on your car.. i have the avant wagon... not the same problem though. just tryin to shoot you some tips... i have a oil leak from my lower oil pan. it sucks.. always putting oil in like every week. thats about to change this week though. i was asking how many miles cause maybe you could just get the timing belt job done like i am.. i ordered the ultimate plus timing kit from ecstuning.com and it comes with a bunch of stuff besides the timing belt.....- water pump and gasket, oil pump gasket, cam seals and a bunch of other things right in that area.. for 450 bucks its a decent value.. i suggest that if your almost due for that job
good luck
leaks only get worse, fix that shizz
good luck
126k miles. Looking at what it'll take to replace that seal I think I might as well just have the timing belt done at the same time, since it has to be taken apart anyway. Sucks cuz I just broke the tie rod mount on the left front and now I don't have enough money to fix the leak! ah well...the car'll settle down after a few months here...right?
xqwizit
Dec 9, 2009 09:26 AM
