2.8 coolant leak...
After changing the timing belt, water pump, thermostat, coolant reservoir, the little bastard still wants to leak coolant. Is there a "typical" place that the 2.8's are prone to leak from. Its apparently dripping down from the front of the oil pan... I previously suspected the waterpump. Any ideas from those familiar with the V6 variety?
Thanks in advance.
Thanks in advance.
There appears to be a coolant "tube" that is visible from the front of of the motor(with the water pump removed). Are there seals (o-ring) that are prone to leak on this part? And I presume this tube runs below the intake manifold to the rear of the motor... yes? I really don't feel like tearing into this car again in this wonderful Texas heat. I hope it is as simple as a hose needing replacement. Any other thoughts?
Thanks-
Thanks-
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
