2 CEL & Transmission Problem
Old Aug 13, 2007 | 10:42 AM
daveplot's Avatar
Default 2 CEL & Transmission Problem
I'm getting a P0422 and P0411 code. From searching here I've found that it's the Cat and Secondary Air.
It has an automatic transmission and the "manual" portion of it no longer works. I go up or down and the car keeps going in automatic mode. Could this be related to the P0411 code if a vacuum line is cracked?
How hard is it to replace the cat? I've done exhaust work on a full size pickup without problems.
Thanks
Old Aug 13, 2007 | 10:49 AM
hiwords's Avatar
Default RE: 2 CEL & Transmission Problem
the transmission problem shouldn't be cuz of vacuum lines. it's probably the circuit thingy right under the shifter that's messed up. s for cat converter i couldn't rly tell u much. haven't needed to do dat much work on ma car yet
Old Aug 13, 2007 | 12:07 PM
akielb's Avatar
There is a magnet on the shifter that senses when you shift - most likely this came loose, no idea how to fix it
Old Aug 13, 2007 | 05:53 PM
david9999's Avatar
Agree with above regarding shift problem. There is a set of magnets that sense when the shifter has been put in tip mode. It frequently slips or falls off.
I am away from home so I can't look up codes. Will try later.
Old Aug 13, 2007 | 06:01 PM
CRAZYHAWK's Avatar
16795 P0411 Sec.Air Inj.Sys Incorrect Flow detected
16806 P0422 Main Catalyst, Bank1 Below Threshold
Old Aug 13, 2007 | 08:22 PM
david9999's Avatar
P0422 most likely means that your car is high mileage and your catalytic converter is shot and needs to be replaced..
for the other code:
Check combination valve. Repair Manual , 1.8 Liter 4-Cyl. 5V Turbo Engine Mechanical, Engine Code(s): AEB, ATW, Repair Group 26; Checking Secondary Air Injection (AIR) system - Check hose setup (Secondary Air Injection -AIR- solenoid valve); check intake system for leaks (false air)Check the vacuum hoses too.
Old Aug 15, 2007 | 03:42 PM
daveplot's Avatar
I cleared the codes and P0432 showed up, which is Main Catalyst Below Threshold (Bank 2).
So now that I've gotten a bank 1 and bank 2 code for the Cat, I'm going to guess it's not a false code and the cat should just be replaced.
The car has 78k miles, but is a year over the 8year 80k mile emissions warranty.
Old Aug 15, 2007 | 04:41 PM
david9999's Avatar
Cant be bank 2. you have a 1.8T. There is no bank 2.
I can't double check the code number as I'm not at home
Old Aug 17, 2007 | 10:09 AM
daveplot's Avatar
I just noticed it's a 2.8.
The car is a company car, so I'm not the daily driver on it.
Old Aug 17, 2007 | 12:46 PM
david9999's Avatar
Bank 2 is the other side oxygen sensor.
