2 CEL & Transmission Problem
Before you go replacing the cat please go get it tested. Po422 is not usally a bad cat a p0420 code is without a doubt a bad cat. P0422 is most common to a faulty o2 sensors. As far as the tip problem there are a few things to check 1. is the black filler slide contains the magnet to move from auto to tip mode side to side. 2. Is the circuit board under the silver plate is a known failure due to drink spills. 3. Also there is a magnetic sol. under the entie mechanism which is another known failure for your problem
If there is something wrong with the secondary air system, couldn't that trigger cat related problems especially during engine warm up? I would make sure everything is okay there first and see if that fixes it. Thoughts?
jassmaster
Jul 19, 2016 11:23 AM
