2 cold weather problems?
1. So I was pulling out of my driveway and for about 5 minutes of driving my powersearing was moaning when I turned. Also it moaned a bit taking off from a stoplight. Could that be belt related? Should I just let it warm up longer or do I have a problem?
2. Maybe I'm just crazy but it looked like the display on the CD player was running slower today? Like the numbers changed slower as it counted the CD time. Instead of 1-2-3 etc it was like 1-fade out- fade in - 2...
as for the first problem i bet you are just low on powersteering fluid, check that first. remember when you fill it up to turn the car back on and check to see if it bubbles, if it makes a lot of bubbles there was a lot of air in the power steering lines. i bet that is the problem.
2. i think you are seeing things rofl
same thing happened to me brought it to dealer and service rep filled it up (power steering fuid, hydraulic mineral oil) it only needed a lil bit like several ounces and then was perfect. asked why it went low and he said it happens all the time
spinradical
Nov 18, 2014 01:46 PM
Shell
Nov 19, 2010 03:07 PM
nya4
Oct 1, 2008 06:00 PM
