2 questions....
Old May 5, 2006 | 06:38 PM
a4r6's Avatar
Default RE: 2 questions....
What is the difference between the J and the H valve?
Old May 5, 2006 | 06:40 PM
a4r6's Avatar
If I'm in limp mode I wouldn't boost to 16 correct?
stu
Old May 5, 2006 | 06:55 PM
onepoint8tee's Avatar
correct.. Good luck... But its probably just heat soak if you are boosting normaly.
Old May 5, 2006 | 07:23 PM
north5995's Avatar
J and H were rated for different thing. No idea how they differ I just know the H was from the RS2s.
Old May 5, 2006 | 07:31 PM
dafrazi's Avatar
I don't think this is a closing throttle body. Here's why.
The drive by cable cars don't have a mechanism for the ECU to close the throttle body; so this can't be the throttle body closing and causing limp mode. The throttle cable attached to the gas pedal opens and closes the throttle body. The DBC cars don't have the ECU controlled electronic throttle bodies that are in the DBW cars. However, the ECU can cut boost through the N75 and cause limp mode.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
