2000 Audi A4 1.8T not starting
Old Mar 20, 2010 | 12:38 AM
theiss2200's Avatar
Default 2000 Audi A4 1.8T not starting
I have a 200 Audi A4 1.8T. It has 115k miles on it. it is getting gas but no spark. I changed the plugs and it started right after that and then the next day it did also. I drove it 45 miles to work no problems. When I was done for the day it didn't start again. I turned it over and then let it sit 20 min and it started. I then went to a store on the way home and came out 15 min later and it started again no problem So I figured it was fixed. I went home and parked it, around 1 hour later I went out to move it into the driveway and it was dead again. Then i turned it over for a while and it finally started, affter turning over on and off for 25 min. I don't want to drain the battery so it has been in my driveway ever since. I changed the coils thinking it could have been them b/c it is getting gas just no spark. I keep trying to start it and it turns over and i can smell the gas just nothing else. Any sugestions for help?
Old Mar 28, 2010 | 12:24 PM
theiss2200's Avatar
Anyone? I need to fix this car
Old May 17, 2010 | 11:36 AM
jcruce's Avatar
I'm having the same problem with my 98 a4 1.8t. Hot starts are okay but cold starts more than one hour after running it won't start. I've tried a ton of stuff. fuel filters, spark plugs, valve cover seals, compression ratios, sensors and still nothing.
cummins4lf
Feb 5, 2015 10:48 AM
adolin22
Mar 25, 2012 10:48 PM
jonik10
Jan 6, 2011 06:48 AM
10510tony
Aug 20, 2009 02:28 PM
mholm
Aug 20, 2006 01:36 PM
