2001 A4 2.8 Quattro please help!
Old Apr 15, 2017 | 05:01 PM
STOOPIDMONKEY's Avatar
Default 2001 A4 2.8 Quattro please help!
2001
​​​​​​A4
​​​​2.8 Quattro
Manual 5 speed
​​​​214,000 miles
So I buy this car and fix all the vacuum leaks she turns out to be a wonderful car. Then one day....
I start her up she runs great as usual, make a couple stops and on the 3rd stop or so she would start. Let her sit for a while and she started right up ran fine no CEL. Took her home hooked her up to my VAG-COM ran a full scan, nothing.... ever since then, if I am out I have to leave the car running because of I shut it off more than 3 times it will not start unless it sits for a while. I have replaced the fuel pump, pump relay, and tested all circuits I can find this one. Please help!
Old Apr 18, 2017 | 10:09 AM
rhodes991's Avatar
Two guesses (and they are guesses):
1. Starter has a dead spot and needs to be replaced.
2. Solenoid on the starter gets warm and that is causing it not to function until it cools down.
When it won't start does it push start by popping the clutch?
ant34uk
Aug 2, 2014 03:55 AM
akarol
Jun 27, 2008 12:51 PM
archer_pilot
Jun 5, 2008 11:59 AM
