2003 a4 1.8t output shaft speed sensor help!!
Old Apr 1, 2013 | 10:00 AM
adrianaborek92's Avatar
Unhappy 2003 a4 1.8t output shaft speed sensor help!!
i have a 2003 a4 1.8t (not quattro) and the*scanner*read output shaft speed sensor problem (po722 i think). Is it possible to replace just this sensor or is it ABSOLUTELY necessary to replace the TCM (module). I'm hearing both views so far. Also, if the module does need replacement, how long/safe it is to drive without replacing it? thanks!
Old Apr 3, 2013 | 08:39 PM
sincityaudi's Avatar
I don't know about the aftermarket possibilities but I do know that Audi doesn't sell the speed sensor seperately and you have to buy a whole TCM. It isn't critical if you havent noticed driviability issues other then the PRND illuminating, but I wouldnt want longer then necessary.
Old Apr 4, 2013 | 10:43 PM
Yeah the PRND is flashing after the rpms jerk up and down, forcing me to pull over sometimes. Only happens in the morning. If there is an aftermarket possibility, I will find it. Also, my acceleration is terrible and gas mileage is even worse. I need to get this fixed :/ Thanks so much for replying, now I know there's some hope
Old Dec 13, 2017 | 04:51 PM
D_troy's Avatar
Im having the same code pop up, has anyone got any results on this issue, my 04 a4, also will not go into gear, would the tcm or speed sensor have anything ti do with this issue, thanks in advance
Bill Davis
Oct 31, 2013 02:59 PM
adrianaborek92
Apr 1, 2013 12:27 AM
shavrovas
B7 Models
Dec 30, 2011 06:32 PM
ZeroAudi
Apr 27, 2011 04:53 PM
neomaxddr
Apr 1, 2009 03:16 AM
