2003 a4, bent something in the rear
Old Jul 15, 2007 | 04:09 PM
objec's Avatar
Default 2003 a4, bent something in the rear
i got a 2003 a4 and it was backed into a wall at 25mpg, the body has a good amount of damage on the rear left side. and the body guy said it can be fixed. but the problem is that the rear left wheel now has excessive toe in it looks like. the camber looks ok but the wheel points inward twords the car. i brought the car up and shook the wheel, nothing is loose. and everything looks somewhat normal.
so what would be the first thing to bend or give away? could the alignment just be off? can the rear toe be adjusted and if so how much.
I plan to replace one part at a time until the wheel is normal.
Old Jul 15, 2007 | 04:10 PM
98jeep5nine's Avatar
Default RE: 2003 a4, bent something is the rear
holy **** 25 mph?!
Old Jul 15, 2007 | 04:19 PM
objec's Avatar
yeah i know.
Old Jul 15, 2007 | 04:29 PM
CLX's Avatar
CLX
Zombie Defense Force
My guess would be a control arm
Old Jul 15, 2007 | 04:35 PM
auditech79's Avatar
Replace everything on the part of the rear end, control arms, spring, sturt, the wheel hub and wheel.
Thats the ONLY way to bring it back to normal, there is almost no way of telling what is damaged un-less it is absolutely obvious.
Old Jul 15, 2007 | 04:38 PM
CLX's Avatar
CLX
Or, you could just find the bent parts, and do the exact same thing on the other side as a performance upgrade!
Old Jul 15, 2007 | 10:59 PM
objec's Avatar
well the spring and shock wont bend, right.
there is a trailing arm and the upper and lower control arms.
what about the nuckel, could that bent.
Old Jul 16, 2007 | 03:52 AM
CLX's Avatar
CLX
Sure, shocks can bend. If it's there, it can be broken. If it were a shock, though, the suspension wouldn't move very well and there would be huge amounts of oil everywhere (unless it already leaked out)
Old Jul 16, 2007 | 11:39 AM
ironman's Avatar
COntrol arms is the best bet but if it took a beating that bad i would do everything and now that its new.
richorrell
Nov 15, 2013 12:51 AM
kl-a4
Dec 31, 2011 06:12 PM
A803
Sep 5, 2007 06:19 PM
A803
Sep 5, 2007 06:16 PM
a4annie
Jan 24, 2005 11:41 PM
