2003 A4 Snap, Crackle, Pop Speaker Problems
Old Dec 12, 2006 | 01:12 AM
pec2402's Avatar
Default 2003 A4 Snap, Crackle, Pop Speaker Problems
Looking for some help w/ my car. I just bought a 2003 Audi A4 with the Bose Premium Sound and there is something really wrong with the stereo/speaker/amplifer. They make crackling/static like sounds on almost every song. Sounds like its coming from multiple speakers. I took the car to a local stereo shop thinking i needed the tweaters replaced, but he checked all speakers and said they are working fine. From here, he was lost. Suggested it could be the amplifier, which is located on the rear passenger's side in the trunk. Does anyone has ANY idea or maybe you've had this problem. Would really appreciate some help b/c i dont know where to turn from here.
Old Dec 13, 2006 | 02:03 AM
pec2402's Avatar
Default RE: 2003 A4 Snap, Crackle, Pop Speaker Problems
I should note, it doesn't affect all songs, some are much worse and while others aren't as bad.
Old Dec 13, 2006 | 02:17 AM
widgget's Avatar
your second post/comment would make me question the head unit, although the amp can easily produce the same symptoms. Personally i would start with the amp and work from there, find a buddy that will let you take his out to test it (or attach your amp to his car) or just man up, log onto ebay, and see if you can find a replacement.
Old Dec 13, 2006 | 02:22 AM
pec2402's Avatar
Tried the ebay thing, very rare and hard to find. Audi wants $670 and thats too much when i'm not sure it's going to work. Is it easy to remove the amp, this is new to me? Thanks.
Old Dec 13, 2006 | 02:34 AM
widgget's Avatar
damn thats a good chunk of change! the amp should be under the rear seat if i remember reading correctly, just pull it up and see, bet it will come out with a few screws.
Old Dec 13, 2006 | 02:45 AM
pec2402's Avatar
i'm going to start w/ the amp, not sure when i'll get to it but thats where i'll begin. if it does end up being the head unit, am i able to put in an aftermarket or b/c it's bose will i have to replace everything? i'm lost when it comes to bose.
Old Dec 13, 2006 | 02:50 AM
eth700's Avatar
Does it make the noise when you play a CD as well?? My 02 a4 does the same thing but only with the radio. I think it's a reception issue...
Old Dec 13, 2006 | 02:51 AM
pec2402's Avatar
cd and radio. it comes from pretty much every speaker so it has to be the amp or the head unit. i just have no idea which one to look into.
Old Dec 13, 2006 | 03:50 AM
tank8970's Avatar
you could just get an aftermarket amp you can find some that are pretty cheap in the 200-300 watt range i donno bout wireing it up tho
Old Dec 13, 2006 | 06:12 PM
pec2402's Avatar
how would i know how many channels i need? they're are 10 total speakers in the car (2 on each door, one on the front dash and a sub in the back). thanks.
jdip
Audi Q5
Apr 27, 2015 12:52 AM
xmu76
Oct 5, 2014 09:30 PM
sci_83
Jul 7, 2012 07:47 AM
kejibelle
Apr 7, 2006 04:19 AM
bernie
Nov 19, 2004 05:11 AM
