2006 a4 a/c compressor not engaging code 01171
Old Jun 9, 2020 | 04:55 PM
slick85225's Avatar
Default 2006 a4 a/c compressor not engaging code 01171
Hello , i'm brand new to this forum , and i have a question on a 2006 A4 1.8T convertible a/c compressor not working , a few days ago it quit blowing cold for a customer of mine, put gauges on it and there is plenty of pressures , checked #1and#6 fuses in drivers side panel and they are ok, got the correct 3R0959126 condenser switch and replaced it and still no compressor function #1 most common issue ? , also i hooked my Autel maxi sys scanner to it and it came back as " 01171 passenger heated seat temp sensor G60 , short to ground " , could this be a relay problem and where would that relay be located, i'm stuck at this point and would like to see if anyone has run across this code and / or some feedback as what to check next and any info would be greatly appreciated and i will keep checking and searching the forums. Thanks
vtraudt
Jun 12, 2019 08:16 AM
Mike Markley
Aug 9, 2016 04:16 PM
ocielz
Sep 23, 2011 06:57 PM
Mattt6511
Aug 31, 2011 11:36 AM
