2006 A4 quatro. bad vibration
Old May 5, 2013 | 01:38 PM
dtk84's Avatar
Default 2006 A4 quatro. bad vibration
I have a 2006 6 speed a4 quattro. I took it out of the driveway today and as I pulled into the street I sped up in first gear until I hit about 5k rpm. Then shifted to second and so on. Well right then the check engine light started flashing. And then noticed that at low rpm in any gear I have a wicked vibration all of a sudden. Opened the hood and saw nothing out of place. No smoke or odd smell. The vibration is quite strong and there is a clear loss of power with attempting to accelerate along with a slightly stronger vibration.
Any thoughts.
Old May 5, 2013 | 04:33 PM
Nebuchadnezzar's Avatar
Are you able to scan it yourself or have a place like Autozone scan it for you? If you can provide us with some codes we might be able to give you some good advice. Until then it's really a guessing game.
This could be a misfire issue, or even a vacuum leak may lead you to describe what you just did in certain instances.
Old May 5, 2013 | 04:58 PM
CryptoStorm's Avatar
If your check engine light is flashing it means that its misfiring.. Go to AutoZone and get it read and the code should tell you what cylinder.
I would first replace all the plugs with a new set of Bosch double platinums. DO NOT GAP THEM
If the misfire is still happening I would replace the coil on the misfiring cylinder.
Old May 5, 2013 | 05:00 PM
PS: Audi has had a recall on some of their coils. You might want to do a search and see if your vin is in the recall
Old May 6, 2013 | 10:37 AM
When I first got my A6 and took it to the dealer, I was surprised that they actually admitted to there being a recall on the coil packs and did it no questions asked. I'm fortunate to live near a good dealer.
slwerner
B7 Models
Feb 19, 2011 08:38 AM
oki
B7 Models
11
Jan 11, 2011 04:12 PM
BlacknTan
Oct 5, 2010 12:56 AM
AudiaA6
Mar 30, 2008 09:27 AM
S3RRO
Jan 30, 2008 12:49 AM
