2nd gear grinding
Old Mar 25, 2007 | 01:13 AM
L.E.O.'s Avatar
Default 2nd gear grinding
On very cold mornings when I start the car (99.5 A41.8TQM)I find whenever I shift down into second I hear/feel the gears grind for a second until it locks in. Now its not a hardcore grindingbut its enough that I feel after so long, itsgot to cause some sort of damage. It only happens for the first few (2-4) shifts into second, then the car starts to warm up and it goes away. Seems to me it has to do with the metal/steel contracting in cold weather overnight. It only happens in second every other gear is fine..
Do you think i should be conscerned? Should i take it to the dealership/mechanic or is there anything i can do myself to see what affect if any its causing?
EDIT: Some mornings I've tried shifting at low and higher rpms making sure I fully push the clutch inall the waybut it still happens every time
Old Mar 25, 2007 | 01:47 AM
wood_e's Avatar
Default RE: 2nd gear grinding
Try putting some GM synchromesh in your trans. It smoothed out my 1-2 shift a lot.
Old Mar 25, 2007 | 03:59 AM
SAudi's Avatar
its probably your synchro going, i have the same prob, do what wood_e said it should help
Old Mar 25, 2007 | 01:53 PM
L.E.O.'s Avatar
ok thanks ill try that
Old Mar 25, 2007 | 09:14 PM
HeIsAudiHere's Avatar
the synchros are known to go out.
Old Mar 25, 2007 | 09:18 PM
L.E.O.'s Avatar
are they expensive to get replaced by a dealership? (no more warrenty) should I have them replace it then put the synchromesh in after?
Old Mar 25, 2007 | 09:28 PM
We just had our TT tranny rebuilt when the 2nd gear sychros went. We were able to remove the tranny ourselves because we were doing other mods.... and it saved a lot of money. We delivered it straight to the tranny shop. That is the route we took. We wanted the tranny rebuilt anyway...
My buddy did drive his for a while with the problem. Just shift to 3rd from 1st lol.
Is there a cheaper fix guys?
Old Mar 25, 2007 | 09:35 PM
wood_e's Avatar
Try changing the fluid before drawing worse conclusions.
projlightning
Oct 10, 2007 10:21 AM
zachaTTack
Jul 26, 2007 06:50 PM
aj
Nov 22, 2006 01:34 PM
MHarrison
Sep 5, 2006 04:16 PM
cukilo
Feb 16, 2005 12:29 PM
