7 Pesky trouble codes.
I keep getting a CEL. The lates cods are;
P0118
P0300
P0302
P1559
P0301
P0304
P0303
I know that one of them is Coolant temp input too high. I replaced the coolant temp sensor a few weeks ago.. But, I'm still getting this same code. I'm wondering if this means tht the signal going TO thecoolant temp sensor is too high.
Many of the other codes are misfires. The plugs looked good about two months ago when I had them out. I did replace th Ignition Control module, which made a worldof difference in how it ran. But, I replaced it with a HUGO brand. I'm wondering if that is giving me the codes.
Ideas anyone?
P0118
P0300
P0302
P1559
P0301
P0304
P0303
Ideas anyone?
Sorry I posted the wrong link: link
Have you cleared your codes? (they don't go away on their own). I've heard of those codes resulting from a bad tank of gas.
Honestly I don't know if the cam position sensor could cause any of this, I just saw that came up with a search of your misfiring problems.
the P1559 code (17967- Throttle valve control part (j338) fault in basic settings
p1559 - 35- 00) could be generated from a dirty throttle body. Try removing it and cleaning it, then do a throttle body alignment. Also check the tension on the throttle body cable at idle (do you have drive by wire?)
