80,000km Tune-up
Old Oct 21, 2007 | 01:45 AM
m5racer's Avatar
Default 80,000km Tune-up
Ok, well i jsut hit the 80,000km mark and wanted to know what
things should be replaced. So far i am doing the following:
Oil change
Transmission and Diff Fluid Change
Fuel Filter Change
Anti Freeze
Did plugs 4000km ago
So becides this are there other items that should be replaced like power steering fluid or anything like that ?
One other thing is my car is now 6 almost 7 years old. Should hte belt be changed now or can i wait another 10,000km or so ?
Thanks a lot.
Anthony
Old Oct 21, 2007 | 01:54 AM
cstarky15's Avatar
Default RE: 80,000km Tune-up
which belt? if timing do it now. better earlier then later and have it fail. at 80k audi did my serp belts too.
Old Oct 21, 2007 | 11:35 AM
CRAZYHAWK's Avatar
Old Oct 21, 2007 | 11:38 AM
hiwords's Avatar
air filter, and if u want do the cabin fitler too. and by the belt, do u mean timing belt or accesory belt? timing belt should be changed every 60,000 miles. accesory belt should be fine unless u see black dust in the area or cracks on the belt.
Old Oct 21, 2007 | 11:40 AM
onepoint8tee's Avatar
You could probably wait another 5-10k miles for the belt/tensioner, but why wait when its the part that makes or breaks your engine? Get it done before the weather turns too cold to make you want to put it off.
CRAZYHAWK's Avatar
I have 132K mi. and have not changed the TIP fluid, power steering fluid
or the fuel filter. The car is running OK.
Old Oct 21, 2007 | 11:41 AM
hiwords's Avatar
car always seems to run ok until one day it doesn't run ok lol. prevention is key to saving money.
Old Oct 21, 2007 | 03:22 PM
veloracer's Avatar
80k km = 50k mi.
You can wait on your timing belt. I would probably wait until you hit 80k miles = 128k km. You should be fine just changing fluids for now.
Old Oct 21, 2007 | 03:46 PM
ORIGINAL: CRAZYHAWK
Why wouldnt you change your tranny fluid? Are you oneof those people who believes in the "life of the car" theory? Remember there are no magical fluids that retain their lube properties forever. I know 10 VW/Audi techs who will tell you the same thing.
Old Oct 22, 2007 | 03:36 PM
CRAZYHAWK's Avatar
I'll wait until there is some indication in the way the TIP shifts.
The fuel filter is also lifetime.
Sheasta
Apr 18, 2012 06:51 PM
sb301
Feb 7, 2012 11:47 PM
cesarnz
Oct 6, 2008 05:14 AM
daviddavoust
Feb 21, 2006 02:19 AM
Nickel_5000tq
Apr 7, 2004 01:20 AM
