97 A4 wont start help
Old Apr 18, 2006 | 11:33 AM
active's Avatar
Default 97 A4 wont start help
i have a 97 p reg audi a4 1.8 with a starting problem
it cranks over but wont start as there is no spark
yet when you bump start it, it starts fine runs fine
ive tried crank sensor, cam sensor, been to the local auto electrican
ive fitted new coil pack, batt, ing switch on the back of they key
ive tried everything
any help please ta.
Old Apr 18, 2006 | 11:48 AM
techbod's Avatar
Default RE: 97 A4 wont start help
ignition switch comes to mind, check all wires are connected to the starter motor
Old Apr 18, 2006 | 01:50 PM
brrman's Avatar
Put the pedal to the floor and turn the key. See if it starts that way. If so, then its likely your coolant temp sensor.
Old Apr 18, 2006 | 06:49 PM
active's Avatar
Hi . Thanks for the info, but I cannot see how putting the pedal to the floor can rectify a spark problem?
Old Apr 18, 2006 | 06:52 PM
active's Avatar
Hi, The car has been to the local auto electriacian and he surley would have picked up on any lose/disconnected wires. Any other ideas!
Old Apr 18, 2006 | 07:26 PM
brrman's Avatar
its not a spark problem if it's the coolant temp sensor to which i referred. The temp sensor, if defective, could be telling your car that it is warmer than it actually is, thus not enough fuel is delivered on crank for a "cold" start.
The pedal to the floor is a very well known and common approach to diagnosing the coolant temp sensor issue. I don't make this crap up, you know.
Old Apr 19, 2006 | 06:51 PM
active's Avatar
i did not say it had a colant temp fault, please read the question
Old Apr 19, 2006 | 06:54 PM
BadLuckAudi's Avatar
Just because you didn’t say it or your car doesn’t know it doesn’t mean it doesn’t have a faulty coolant temp sensor, as long as the sensor is giving the motor a temp then its going to THINK its working while in reality its not, you should check it out
Old Apr 20, 2006 | 02:32 PM
brrman's Avatar
lol - got get your car read for codes... until then no one can help you.
Old Apr 20, 2006 | 02:46 PM
techbod's Avatar
yep I agree he can bump start it and all is well then its a cheap battery with no cranking amps or not enough for the car, it has to have codes stored on a no start situation
