98 audi 1.8t heater and overheatin troubles
Old Dec 2, 2007 | 07:48 PM
xeni81's Avatar
Default 98 audi 1.8t heater and overheatin troubles
ok i have a 98 audi and recently my heater is only blowin cold air my temperature is going all the way till the warning light comes on and even my oil is gettin hotter all at the same time,i did replace the thermostat and the coolant temp sensor and it still doing the same thing,does anybody know what else it might be,any input would be great help.
Old Dec 2, 2007 | 07:52 PM
onepoint8tee's Avatar
Default RE: 98 audi 1.8t heater and overheatin troubles
Sounds like you have air bubble in the coolant lines. There is a bleeder screw on the heater core, or you can bleed through the drain on the radiator. Dont drive with it like that, you could warp a head and end up with a leaking head gasket [:'(]
Old Dec 2, 2007 | 08:03 PM
xeni81's Avatar
yeah,i'm not driving it,it's been more than 2 weeks ,ever since i had to drill out the broken bolts on the exhaust manifold(yeah 2 out of 3 bolts snapped)then this started happening,i heard it could also be a water pump,coul it?
Old Dec 2, 2007 | 08:08 PM
If it was your water pump, youd hear a gawdawful sound coming from it. The impellor is plastic (if not upgraded to the metal type) and shatters over time causing the bits of pieces to clank around inside the pump housing. Hopefully you didnt put the thermostat in backwards
Garrett8
Dec 10, 2014 02:15 PM
Garrett8
Dec 7, 2014 02:06 PM
sickquattro915
Sep 3, 2008 09:53 AM
doddy
Jan 1, 2005 11:05 AM
ozziepeck
Nov 26, 2004 07:33 AM
