99.5 amp/sub install q's
im usin a loc for now, so i found the preamp in my trunk and i've run my power cable, but i cant seem to find the pinout for the 99.5 amp, and i didnt wanna go with 97 or 00 cuz im just not sure if its the same. anyone wanna lemme in on wut wires/colors should tap into what? im pretty sure my remote line is the white one but im fuzzy on everything else. appreciate the help.
alrite so now heres the situation...all i did under the hood was disconnect the battery and run the power wire for the amp, heres the problem, my car wont go past 1600 rpms...wtf?? just to be clear i disconnected the (-) battery terminal and now i cant get out of first gear?? what the **** do i tell my parents?? and even more what the **** is wrong with my car?? im totally baffled and would love to be ebtertained by any ****ing ideas
post it in the a4 section, its way more active and you;ll get a lot more responses, i personally dont know too much about elctronics, try disconnecting it again and reconnecting
You need to connect RCA's in by splicing in the the RR and LR and comm grnd its not hard
ORIGINAL: im_audi_herr
honestly im not even worried about the subs right now, i really need to figure out how to fix my ****. disconnected a wire that runs to my ecu, so can sumbody tell me what i did to my car by doing so? it wont even start now and it had no mechanical problems before i attempted this install (subs) [:'(]
