99 A6 2.8 problem
Old Feb 13, 2005 | 11:46 PM
squid121's Avatar
Default 99 A6 2.8 problem
Timing belt broke a few days ago, car shut off like you turned the key off, no noises. Engine still turned over with starter, wouldn't start but no noises. Wanted to know if when this happens will the piston hit the valves resulting in bent valves and damage to the head and pistons or is this a "non conflict" type engine? Local shop (not dealer) says that heads are ruined( did not remove heads to inspect) and says that cams are locked up. If I put a new timing belt on and set the timing, should it start and be ok? Anyone have any info/ knowledge they can share will be greatly appreciated.
Old Feb 14, 2005 | 02:22 AM
Jestnomen's Avatar
6th Gear
Default RE: 99 A6 2.8 problem
Hi squid121, welcome to the forum. Yes Audi's have interferance engines. If the timing belt snaps, the the valves will come in contact with the cylinders. I'm sure they are toasted.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
