A4 1.8 Brake Issues
Old May 15, 2006 | 12:58 AM
starigurl's Avatar
Default A4 1.8 Brake Issues
Hi There,
I've looked through the forum here, but haven't found anything conclusive. If there is an answer here already, please let me know.
I have an A4 1.8, 2001.
I have issues with the brakes at low speeds. When driving in the city and the constant creeping and slow stops the brakes squeal awful. This is not a problem with higher speed braking... I'd say it only makes noise when the brakes are applied at less than 10kph.
I had the dealership replace the pads but this didn't change anything. Are there replacement pads, harder or softer that will not squeal? If so can someone recommend a vendor, or shop that will be able to correct this problem. The dealership is uncooperative.
Thanks!
Old May 15, 2006 | 01:31 AM
impaler2383's Avatar
Default RE: A4 1.8 Brake Issues
new pads will squeak. I'm in the process of breaking mine in. give it a week or two.
Old May 15, 2006 | 01:41 AM
StepUpProductions's Avatar
yea id say see if the new pads stop squaling after a while, they might be breaking in, but if it still continues in the same way the old ones did, id get the rotors checked
Ramathorn
Feb 13, 2012 05:07 PM
gorac369
Jan 28, 2010 07:43 PM
JorgenA4
Apr 28, 2009 04:42 PM
a4b5guy
Jan 25, 2008 08:20 PM
KevinA
Oct 21, 2007 05:18 PM
