A4 1.8T Converter Needed
Old Nov 13, 2007 | 09:53 AM
crissycut's Avatar
Default A4 1.8T Converter Needed
I'm looking for a CA approved Cat Converter for my 97 Audi 1.8T. If anyone knows where to get one that is reasonably cheap, please let me know. Even a used one will do. Thanks.
Old Nov 13, 2007 | 10:12 AM
hiwords's Avatar
Default RE: A4 1.8T Converter Needed
here u go. one of the cheapest i found. might be a bit of a PITA to fit since it's universal but it should work.
http://cgi.ebay.com/ebaymotors/Audi-...spagenameZWD1V
Old Nov 13, 2007 | 05:51 PM
david9999's Avatar
There is a company that has CARB approved aftermarket cats for about 190 dollars. Unfortunately I don't have the link. Try running a google search. That is how I found them in the first place.
Old Nov 14, 2007 | 10:12 AM
crissycut's Avatar
Thanks guys. I'm just looking all over as well. Are magna's California approved? If so, how much do you think it'll cost to fit it? last time I checked, they're charging about $500. I'm actually eying for a GOOD usedoriginal part so I could just bolt it on. The car is actually a 97 A4 and is quite old to spend big $s.
Old Nov 14, 2007 | 10:36 AM
onepoint8tee's Avatar
ORIGINAL: hiwords
It says " *Not legalfor useon California OBD2(96/up) vehicles"
Old Nov 16, 2007 | 08:36 PM
loopys_a4's Avatar
if you have a down pipe i will trade
Old Nov 16, 2007 | 08:42 PM
Bogie's Avatar
You'll also be buying 2 gaskets (1 to the flexpipe and 1 to the turbo), and new bolts aren't a bad idea, either. Good luck if you're doing it yourself. Hope you have some nice high jackstands or a lift.
Old Nov 16, 2007 | 08:58 PM
FASTER's Avatar
Tech Slut
labree can probably set you up with what you need, i think they are based in ca so i dont know why they wouldnt have one
Old Nov 17, 2007 | 10:44 AM
Huck's Avatar
Call Labree Motorsports. I am pretty sure he told me his cats were CARB approved. It cost me $100 to remove my old cat and put the Labree on. The Labree was $269 plus shipping. Beautiful piece of work plus it's high flow.
Huck
thenjd
Jan 23, 2008 04:00 AM
cmndas94
Jan 3, 2008 05:17 PM
crissycut
Nov 14, 2007 09:50 AM
j0hn47h0n
Sep 4, 2007 02:27 AM
