A4 - 1.8T tiptronic Transmission oil change
Old Oct 16, 2007 | 09:53 PM
mimgq2's Avatar
Default A4 - 1.8T tiptronic Transmission oil change
ok folks, I have read a lot about this over the years but what is the real deal with the transmission fluid for the tip tronic trans. Can I just drain this LT71141 - ATF fluidand replace with the new Multi-Vehicle ATF fluid now being offered by many companies?
ie:
Castrol Multi-Vehicle ATF provides customers with a single ATF product that
meets multiple specifications.
Multi-Vehicle ATF provides the following benefits:
- Enhanced friction durability for smooth transmission operation
- Exceptional high temperature protection to effectively resist fluid
oxidation
- Superb low temperature fluidity for cold weather shifting.
Castrol Multi-Vehicle ATF is recommended for use for the following
specifications:
1. ATF+, ATF+2, ATF+2 Type 7176
2. Mitsubishi Diamond SP-II and SP-III
3. ATF+3, ATF+4
4. Nissan Matic-D and Matic-J
5. BMW LT71141 and LA2634
6. Toyota Type T, T-III and T-IV
7. Dexron, Dexron-II and Dexron-IID
8. Voith 55.6335.32 (G607)
9. Honda ATF-Z1 (except CVTs)
10. Volvo (except 5-speed)
11. MAN 339F
12. ZF TE-ML 14B and TE-ML 16L
Old Oct 16, 2007 | 09:56 PM
hiwords's Avatar
Default RE: A4 - 1.8T tiptronic Transmission oil change
i recommend redline. i think they make a ATF kind
Old Oct 17, 2007 | 01:38 AM
david9999's Avatar
I'd just use OEM. Why risk a 5000 dollar transmission to save a few bucks.
AudiOso
Dec 11, 2015 10:56 AM
jonno77
Jun 11, 2007 05:12 PM
EuroAudi
Jul 13, 2006 02:03 AM
Roger1293
Mar 17, 2006 12:08 PM
