HELP - Transmission Oil - 2.7T Tiptronic
Old Jun 11, 2007 | 04:37 PM
jonno77's Avatar
Default HELP - Transmission Oil - 2.7T Tiptronic
Just wondering what I should be using to refill my transmission. I have read plenty on the factory ESSO EGL71141. I read a little about the VW auto tranny fluid. What should I be looking for if I go to the VW dealer? Is there NOT a good store bought brand I can use instead of factory fluid? I just need to refill the pan. Yes I made the transmission instead of engine oil mystake. How much oil did I drain out??
Any help please!
Old Jun 11, 2007 | 04:40 PM
Jeffla's Avatar
Default RE: HELP - Transmission Oil - 2.7T Tiptronic
You emptied around 4 quarts. Just go to the dealer and buy it. I would buy 5.
Jeff
Old Jun 11, 2007 | 05:12 PM
2k S4's Avatar
You might as well flush it, & put in a new trans filter.
Do a search, we have talked about the proper way to flush & fill the trans. You will need a pump for the fluid.
I put Redline D4 ATF in mine, so it seams to like it.
rmr1499
Jul 16, 2013 01:11 PM
the Anno
Sep 18, 2011 08:05 PM
vanbragt
Apr 18, 2010 10:45 AM
h8state
Mar 31, 2008 10:15 AM
matoida6twin
Mar 1, 2007 07:49 PM
