A4 1.9 tdi STARTING PROBLEMS
Old Mar 22, 2006 | 08:23 AM
crohwer's Avatar
Default A4 1.9 tdi STARTING PROBLEMS
Hi -
I own a 2001 A4 1.9 tdi (5 spd manual vesion) (70 000km). Lately, when the motor is cold, it doesn't start easily. The engine turns for at least 5 or 6 seconds, and then only fires[:@][:@]. I had the compression checked, it's still over 19:1 on all four cylinders! What can be wrong? I hear that this problem is common, and usually related to compression loss. I was also told that this can usually only be fixed by replacing the entire engine...
PLEASE give advice / comments. the problem is getting worse.
Also - the gear box takes at least 20mins of driving to warm up properly! This shouldnt be the case, surely!!!
thanks,
Chris
(14608774@sun.ac.za)
Old Mar 25, 2006 | 05:44 PM
dankhound's Avatar
Default RE: A4 1.9 tdi STARTING PROBLEMS
Theres no way a compression test could get you a ratio. Are you sure its not a glow plug issue? Also make sure there isnt carbon buildup around the egr valve.
Old Mar 25, 2006 | 06:03 PM
techbod's Avatar
yep im for the glow plugs also
Old Mar 25, 2006 | 06:07 PM
liquidxit2's Avatar
glow plugs are the most common
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
