A4 - ABS Problem?
Old Jun 23, 2010 | 02:18 PM
tangerine's Avatar
Default A4 - ABS Problem?
I have just replaced the Rear Disc Pads and the Front Pads and Discs.
After putting it all back together, I appear to have a problem with the ABS.
I get either of 2 situations: The ABS light flashes but the brakes work perfectly or the light stays out but the ABS cuts in whenever the brakes are used.
Does anyone have any ideas on what may be causing this (There was no problem with the ABS until I changed the items above.)
Any help would be appreciated.
Old Jun 23, 2010 | 03:29 PM
turbo kraut's Avatar
Tech Guru
without knowing the exact year of the car, we can give you general answers
first are you sure you hooked everything back up properly, and while changing these items did you by chance bust something inadvertently? next thing is one of your abs sensors might have decided to take a **** or be getting ready to take a **** right about the time you changed the other stuff or your module might be taking a ****
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
