A4 Engine Mount Fix Help
Old Jan 4, 2008 | 12:45 PM
killi101's Avatar
Default A4 Engine Mount Fix Help
I have a 2001 A4 2.8 Quattro and I just got back from the stealerships checkup and they're saying both my front engine mounts need to be replaced. They want to charge $750 out the door... can't afford too much right now so I'm wondering if I can do the replacement myself. Is this something I should even attempt? If so, is there a write-up on doing the fix? And what mounts should I look into buying? Any help would be great. Thanks
Old Jan 4, 2008 | 01:57 PM
LowA4's Avatar
Default RE: A4 Engine Mount Fix Help
They are simple, I did both of mine in an hour, if that. You have to remove the 4 13mm nuts holding the swaybar on and let it swing out of the way. Then remove the 6 (3 on each side). that hold the engine mount cradle/swaybar mount. Also remove the 10mm center motor mount bolt. use a stubby 10mm wrench to get the top motor mount bolt out. Here is a writeup on the 1.8 but it's basically the same.
http://www.audiworld.com/tech/eng57.shtml
You can buy the stock motor mounts from Purems.com or you can get the 034 street mounts, which I have, they are a little stiffer than stocks and don't vibe. They are about 180 for both
Old Jan 4, 2008 | 02:18 PM
SAudi's Avatar
what he said an if you go with performance mounts you may as well upgrade the snub and have a nice locked down engine.
Old Jan 4, 2008 | 02:24 PM
killi101's Avatar
What do you guys think about the RS4 mounts? Also, where can I get the 034 mounts? I'm in LA and hoping to do the fix this weekend, any ideas for a local seller??
Old Jan 4, 2008 | 02:45 PM
killi101's Avatar
Thanks for everything so far, this REALLY helps!
What do you think about the RS4 mounts? Also, where can I get the 034 mounts? I'm in LA and hoping to do the fix this weekend, any ideas for a local seller??
Old Jan 4, 2008 | 03:26 PM
Bogie's Avatar
www.034motorsport.comis where they are.
Old Jan 4, 2008 | 06:52 PM
LowA4's Avatar
I would go with 034 mounts, they are cheaper I believe and I heard the RS4's vibe a little.
Old Jan 4, 2008 | 08:56 PM
killi101's Avatar
Just ordered the 034 Mount kit (including snub mount) Will be doing the install early next week. Hopefully everything will go smooth! Thanks forall yourhelp.
Old Jan 4, 2008 | 11:22 PM
LowA4's Avatar
[sm=wootwoot.gif]You won't be disappointed. You'll notice a big difference.
edrocks3
Dec 9, 2008 10:11 AM
audiboyy
Jan 22, 2008 11:34 PM
mitsuman
Jun 28, 2007 03:05 PM
chosos
May 14, 2007 08:06 AM
A4_Spooler
Mar 11, 2006 02:11 PM
