A4 FAN PROBLEM
Old Dec 29, 2005 | 11:16 PM
INFLUENCE's Avatar
Default A4 FAN PROBLEM
LOOK i NEED HELPI HAVE A 1998 A4 2.8 AND I'M HAVING PROBLEMS WITH THE FAN ON THE LEFT SID OF THE ENGINE IT WILL NOT GO OFF EVEN WHEN THE CAR IS WARM. OR IT WILL STAY ON WHEN I TURN THE CAR OFF. I END UP HAVING TO UNHOOK THE MAIN LINE TO MY BATTERY HAS ANYONE EVER HAD THIS PROBLEM....
Old Dec 29, 2005 | 11:42 PM
tip5's Avatar
Default RE: A4 FAN PROBLEM
LOOK! Do a search on the subject.
Old Dec 30, 2005 | 01:59 AM
flyboy's Avatar
how long dose it stay on I wouldn't worry unless it is running for like 30 min after I turned the car off. I measurs a couple diff temps in diff places and turns it on from there. one last thing, is the car overheating.
Old Dec 30, 2005 | 06:04 AM
trailboss's Avatar
Can you stop the fan while the car is running? If you can the fan clutch is toast. Don't stick your hand in there but also if the fan stays spinning after you shut the car off that is a sign that the fan clutch has failed.
Old Dec 30, 2005 | 06:07 AM
flyboy's Avatar
man I feel feckin stupid, I was talking bout the electric one. ^^^ that would be right.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
