A4 Lowering
Old Dec 11, 2005 | 12:51 PM
GASMARK9's Avatar
Default A4 Lowering
Iv Lowered my a4 40mm with 18" wheels but its still not low enough is there any way i can drop it just a little bit lower?
Somebody mentioned using compression clamps that caravan people use so the car isnt going up and down a lot when they are pulling it?
Old Dec 11, 2005 | 01:21 PM
AUDI05's Avatar
Default RE: A4 Lowering
hey man. I was and am still in your same position. I put Eibach pro springs on and it didnt lower it enough! The only way you can close the gap between your fender and wheel is coilovers, or like H&R springs and Bilstein shocks.
But Never put spring clamps on your car! this is why: Your spring is designed to travel a certain distance.
*for example: you have a long spring right, now if you wanted it to be affective you'd make it soft so it can "travel" and cushion bumps, you wouldnt want it stiff.
***So if you clamped your spring it still going to want to travel as far as it was designed to. So if the spring travels 3inch's and you lower the car 2inchs you will be smaking ground allot. so many, many people have bottom'd out "like everday" and messed up their cars really bad.
Dont put spring clamps on an Audi
Old Dec 11, 2005 | 02:32 PM
prodrive's Avatar
I am not sure but there must be 60mm Eibach springs ..
Old Dec 11, 2005 | 02:37 PM
juju4uofa's Avatar
Unless you're quattro you could get Tein S-techs they're pretty low.
Old Dec 11, 2005 | 03:54 PM
98 A4 Turbo's Avatar
im pretty sure wen my cousin dropped his mustang and found that it wasnt low enough, he literally cut a coil or 2 off the shock and that solved the problem... not sure if that would work on ur car though lol
Old Dec 11, 2005 | 04:37 PM
sandman's Avatar
more details would help... if you have bilstein shocks you may be lucky enough to have the one with adjusting rings. if you just bought springs i really wouldnt reccomend going lower w/ stock shocks. but if the shocks are aftermarket designed for lower suspension buy some neuspeed springs, they are low and cheap, all over ebay.
Old Dec 11, 2005 | 05:44 PM
CnB's Avatar
CnB
can i ask what you guys mean with not low enough ?
any pictures maybe ?
i know back with my old car a Jetta i had 18's and lowered it 50mm with eibach springs
it was pretty low
the Audi got right now is still stock(winter and all) but after the winter its going down
probably FK coilovers
a friend of mine told me Apexi is nice also, but i got no idea about that since i am not living in the US where those things are actually used alot i think
never heard of their springs or coilovers though
djnick
Dec 12, 2009 11:07 PM
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
