a4 manual headlight adjust
Old Feb 12, 2007 | 12:38 AM
TBarCYa's Avatar
Default a4 manual headlight adjust
I was searching for information about possibly adjusting my headlights manually since the automatic system isn't working and the lights are pointed at the ground. I was able to find information about how to adjust the A6 lights, but don't know if it is the same for my 03 A4. Any help is appreciated.
Old Feb 12, 2007 | 12:57 AM
i2onnel's Avatar
Default RE: a4 manual headlight adjust
Did you turn your car on without the headlights plugged in? You can use the vagcom to fix that, I think..
Old Feb 12, 2007 | 12:41 PM
TBarCYa's Avatar
The previous owner may have done that but I have not. I just picked up the car about 10 days ago and other than installing XM and replacing a foglight, I haven't done anything to it. Now that you mention it tho, when I replaced the foglight I noticed that there is no molded plug that connects to the bulb. Instead, there are two factory-style metal connectors that individually plug onto the bulb. I thought this was odd and maybe the PO had done something wierd with the lights or the front end and caused the issue.
On a VAG-COM note, there are cables on ebay for around $30 and links to download the software for free. Is this all that is needed to be able to troubleshoot and/or resolve this issue or does the software need to be registered?
Thanks.
Old Feb 12, 2007 | 05:18 PM
sandman's Avatar
youre best best is to look around the rear of the headlight houding. see if you can find some sort of **** or gears. on my b5 its easy to find. they are obvious white *****, that is valeo though.
padylam
May 9, 2011 06:22 PM
a6.nh
May 2, 2010 09:19 PM
jshamren
Aug 31, 2007 05:42 PM
TBarCYa
Feb 15, 2007 04:33 AM
xxxdmx
May 27, 2006 01:09 PM
